Date/Time: Tue, 29 Sep 2026 14:19:36 +0000
Still can not change Candlestick colors
View Count: 1167
[2022-10-20 16:53:43]
User278435 - Posts: 12
The only thing I can change is the background color, the candlestick color does not change.
Steps I did: Chart- Graphic settings Chart- uncheck: Use Global Graphic Settings Instead - Bar High Low Down:
Black - Bar High Low Up: White - Aply Nothing changed!
Thanks,
Paul.
[2022-10-20 19:32:37]
John - SC Support - Posts: 48050
Candlesticks and OHLC bars have separate graphics settings. Refer to the following for the beginning of the Candlestick settings:
Graphics Settings: Candlestick Up Outline
