Date/Time: Wed, 25 Nov 2026 18:27:13 +0000
Rithmic data and trading evaluator
View Count: 733
[2022-10-18 11:41:09]
OriolCasas - Posts: 190
Is it possible to use Rithmic data and connect to the trading evaluator.
Thank you
[2022-10-18 15:52:21]
John - SC Support - Posts: 48658
There is not a way to do this.
What you can do is use the Delayed Streaming Data we provide along with the Delayed Trading Evaluator.
[2022-10-18 16:39:38]
Sierra_Chart Engineering - Posts: 25481
You need to use two separate installations of Sierra Chart. One for Rithmic and one for the trading evaluator:
Using Multiple Data and Trading Services at the Same Time
[2022-10-18 16:43:14]
User707307 - Posts: 84
Ok, does a new instance count as that?
Thank you
[2022-10-18 16:45:35]
They need to be completely separate installations and not an instance of Sierra Chart started with File >> New Instance.
