Date/Time: Tue, 24 Nov 2026 17:34:47 +0000
Data Issues
View Count: 644
| [2022-10-17 18:44:23] |
| InvestmentCLB - Posts: 11 |
My TPO charts for the ES are not updating. There are missing periods and it's only happening on the ES TPO charts
| [2022-10-18 14:35:04] |
| John - SC Support - Posts: 48640 |
We assume you are referring to the missing 'F' and 'G' blocks. If this is correct, then the first thing to look at is whether those letters are in the list of letters to use. Refer to the following: https://www.sierrachart.com/index.php?page=doc/TimePriceOpportunityCharts.html#Input_TPOLetterSequence If the letters are listed properly, then you would need to check if there may not have been any trading during those times by looking at the underlying data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
