Date/Time: Wed, 18 Nov 2026 14:58:02 +0000
Auto reset the 'trade window for chart' attached orders after flatten
View Count: 670
| [2022-10-14 19:36:23] |
| User132992 - Posts: 34 |
Hi support, Is there any way to auto reset the trade window attached orders configuration after flattening on a trade? When Iām scaling out of a winning trade I have to manually change the number of contracts from the original attached order (lets say I start with 4 on a saved configuration), to 1 contract to scale out over the trade at different points. The problem is that I always forget to switch back to the number of contracts for the original attached order setting (4) and then Im getting in to another trade (inevitably it starts going in my favour) and I realise I only have 1 contract selected (because I forgot to switch back at the end of the last trade when I flattened). Please help! ND š |
| [2022-10-14 22:15:21] |
| John - SC Support - Posts: 48570 |
There is not a built-in way to do this. You would have to create a custom study to do what you want. Keep in mind you can create control bar buttons to select a specific trade configuration. Refer to the following: Basic Trading and the Trade Window: Selecting/Using a Trade Window Configuration For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
