Date/Time: Wed, 18 Nov 2026 14:58:03 +0000
Data Range in file to (readonly) : 2022-06-17
View Count: 692
[2022-10-14 18:39:51]
Dh27071975 - Posts: 1
I have an issue with my account. When I am using a new bookchart, I have all the data in live.
But when I open an existing Bookchart : CB EUREX Trading, I don't have tje live data and I am blocked the 2022-06-17.
I tried to change this parameter but it is in read only mode.
I tried to change the Load data limiting method, but it doens't work.
Please, could you help me ? I searched in the support site forum, but I didn't find anything .
Thanks for your support,
[2022-10-14 22:08:56]
John - SC Support - Posts: 48570
Most likely that Chartbook that you are opening has an expired Futures Contract that you are viewing. When you open the Chartbook do you get a message stating that the "symbol needs rollover"?
If you get the above message, then you can click on it to perform the rollover, or you can select Chart >> Perform Futures Symbol Rollover. Refer to the following for this option:
Chart Menu: Perform Futures Symbol Rollover (Chart menu)
