Date/Time: Wed, 18 Nov 2026 14:58:04 +0000
Removing Gold And Crude Oil, CME Nasdaq Only
View Count: 705
| [2022-10-14 18:33:34] |
| meltradeer - Posts: 3 |
Removing Gold And Crude Oil I only want Nasdaq CME (AMP Futures), how do I remove Full CME Package and set up CME Nasdaq Only?
| [2022-10-14 21:36:27] |
| John - SC Support - Posts: 48570 |
It's just a matter of deactivating the exchanges you do not want and activating the one you do. The NASDAQ E-Mini and E-Mini Micro are traded on the CME Exchange, so if you just need access to that data without Market Depth, then you would want to activate the following exchange: - CME non-professional top-of-book You would make these changes at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges We just want to point out that whenever you activate an exchange, you will pay the full amount for the exchange for the remainder of the month in which you activated it. Therefore, if you were to activate the above exchange, you will pay the full $1.25 for the exchange for the remainder of the month of October and then pay $1.25 again on November 1, 2022. Also, we see that you deactivated the Full CME Group, but you will continue to get that data through the end of the month. Therefore, the cheapest way to do this is to wait until November 1, 2022 and then activate the new exchange. You just have to remember to do so. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
