Date/Time: Wed, 18 Nov 2026 14:58:02 +0000
dom replay not working
View Count: 728
| [2022-10-14 17:29:03] |
| User639168 - Posts: 2 |
please find attached pic of the problem i am encountering while replaying the dom. the data services is set to sc. kindly advise. thanks |
| [2022-10-14 17:53:46] |
| John - SC Support - Posts: 48570 |
We need some specific information on what the problem is. Offhand, we do not see anything that stands out as being "wrong".
| [2022-10-15 00:02:29] |
Hi the limit orders are showing as 1 in both doms. The coloumns are missing. Secondly on the left of the price it is showing 1-50% which i have never seen before. Thanks |
| [2022-10-15 18:43:36] |
| Sierra_Chart Engineering - Posts: 25439 |
What you describe does make sense if there is no market depth data available during a replay. So this is all normal. If you want to replay market depth data, refer to: Replaying Charts: Replaying of Market Depth Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
