Date/Time: Tue, 17 Nov 2026 14:05:50 +0000
Chartbook file not found
View Count: 597
| [2022-10-14 15:31:52] |
| DblArrow - Posts: 10 |
Chartbook file not found: D:\Sierrachart....... Message Log: (shows proper direction) Program path E:\Sierrachart.... Data Files path: E:\Sierrachart.... This is the error I am receiving when trying to open a chartbook. All Sierrachart is in E: General Setting>Data points to E: My chartbooks are still in the data folder. Anyway to point to them? My study collections are still working, I can open a new chartbook and chart and apply Analysis (which is the same folder, I believe.) I have tried to reinstall. Have tried running Sierrachart using the .exe file in the E:\Sierrachart folder (don't think its a shortcut issue) |
| [2022-10-14 17:42:41] |
| John - SC Support - Posts: 48547 |
If you are trying to open the chartbook using the Recent Files, then do not do this. Instead, use File >> Open Chartbook. Let us know if you are still having issues when you open the Open Chartbook window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
