Date/Time: Tue, 17 Nov 2026 14:05:50 +0000
Trade DOM questions
View Count: 693
[2022-10-14 14:49:35]
Steve Leon - Posts: 319
I am attaching a screenshot.
1) Does the function that controls the width of the volume profile relative to all the volume profiles on the chart work on the Trade DOM
I am displaying two volume profiles side by side and have that selected but it does not seem to adjust relative to size ?
2) Is there a way to add a study to the list of studies on the Trade DOM. For example Daily OHLC ? Or is the only way to display that using a separate chart and study subgraphs ?
Thank you
imageSierra Chart Trade DOM Relative VP size.PNG / V - Attached On 2022-10-14 14:48:45 UTC - Size: 469.18 KB - 280 views
[2022-10-14 17:16:47]
John - SC Support - Posts: 48547
1. This option really only applies when using a single Volume by Price study with Multiple profiles. In other words, what you are seeing is normal, and it is not related to the Trading DOM. Refer to the documentation here:
Volume By Price Study: Volume Profile Bars Length Relative to All Visible Profiles
2. There is not a way to add a study to the list of studies, but you can get to the larger list of studies and add them directly. Refer to the following:
Chart Trading and the Chart DOM: Adding Studies on a Trade DOM
