Date/Time: Sat, 14 Nov 2026 12:32:50 +0000
Automated Watchlist Scroll
View Count: 654
| [2022-10-14 09:27:25] |
| Cass0wary - Posts: 3 |
Hi folks, is it possible to have my watchlist which is linked to my chart automatically scroll through each symbol on a loop? Say every x seconds it would move to the next symbol? If this does not exist would it be possible for me to write this as a study leveraging existing interfaces or would this not be possible? |
| [2022-10-14 09:38:35] |
| Sierra_Chart Engineering - Posts: 25425 |
Yes this can be done through using the Scan commands on the Chart menu: Changing the Symbol of a Chart: Scanning And then you can adjust the Chart Update Interval in the chart you are doing the scan in, to adjust the scan speed: Chart Settings: Chart Update Interval in Milliseconds (Chart >> Chart Settings >> Display >> Chart Update Interval menu) And certainly you can use ACSIL to programmatically change the symbol: ACSIL Interface Members - Variables and Arrays: sc.DataFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-14 09:41:14
