Date/Time: Tue, 17 Nov 2026 14:05:49 +0000
Chartbook not opening
View Count: 1088
[2022-10-10 15:23:13]
User754757 - Posts: 8
Hey,
I tried opening a chartbook but its saying that it's not compatible and asked me to contact support for help.
what do i do?
[2022-10-10 17:07:37]
John - SC Support - Posts: 48547
Please attach the chartbook to this thread and we will update it for you. Refer to the following for instructions on how to attach a file:
[2022-10-12 19:47:11]
Hey i wanted to open the attached chartbooks but they ain't opening its saying "symbol settings not found for current service" please help me with the installation of these chartbooks and do lemme know if i can open them only when i get the subscription.
attachmentNADRO_ES.Cht - Attached On 2022-10-12 19:36:23 UTC - Size: 37.49 KB - 560 views
attachmentNADRO_CL.Cht - Attached On 2022-10-12 19:36:35 UTC - Size: 38.14 KB - 213 views
[2022-10-12 21:19:39]
The error "Symbol Settings not found for current service" means that you need to update the symbols in the chart.
To do this, open the Chartbooks and then select Edit >> Translate Symbols to Current Service. You should be fine after that.
[2022-10-14 12:52:40]
User679790 - Posts: 3
Please can you also help me with these attached chartbooks? I get the not compatible message.
attachmentJT-FootprintTemplate.Cht - Attached On 2022-10-14 12:50:58 UTC - Size: 49.26 KB - 362 views
attachmentJT-TICK-NYSE.Cht - Attached On 2022-10-14 12:51:07 UTC - Size: 67.68 KB - 446 views
attachmentJT-Volume-Delta.Cht - Attached On 2022-10-14 12:51:15 UTC - Size: 6.87 KB - 465 views
[2022-10-14 12:54:02]
I am adding one more chartbook as well to the above request. Any help or guidance on this will be much appreciated.
attachmentTradingFibz Template Basic.cht - Attached On 2022-10-14 12:53:52 UTC - Size: 165.71 KB - 303 views
[2022-10-14 14:34:34]
Attached are the updated chartbooks.
attachmentJT-FootprintTemplate.Cht - Attached On 2022-10-14 14:34:10 UTC - Size: 4.46 KB - 310 views
attachmentJT-TICK-NYSE.Cht - Attached On 2022-10-14 14:34:17 UTC - Size: 4.41 KB - 321 views
attachmentJT-Volume-Delta.Cht - Attached On 2022-10-14 14:34:24 UTC - Size: 4.83 KB - 284 views
attachmentTradingFibz Template Basic.cht - Attached On 2022-10-14 14:34:30 UTC - Size: 10.04 KB - 279 views
[2022-10-14 16:00:28]
Super! Thank you very much. I can't thank you enough for swiftly turning around.
