Date/Time: Wed, 23 Sep 2026 10:19:23 +0000
Socket still supported in ACSIL?
View Count: 757
| [2022-10-02 09:31:31] |
| Sierra_Chart Engineering - Posts: 24945 |
Yes you can certainly do this. There are no restrictions on this. You have full access to the C++ language and the Windows API.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-02 09:31:38
