Date/Time: Fri, 20 Nov 2026 09:27:25 +0000
SIERRA + DENALI which minimal package
View Count: 667
| [2022-09-30 17:48:37] |
| User361939 - Posts: 170 |
Hello, Could you provide information: If someone needs Sierra with real time data from Denali, would be enough get package 3 ? (No trading, just receiving data) If someone needs to trade as well e.g with TETON routing, package 3 would be enough or needs to go into higher package? Date Time Of Last Edit: 2022-09-30 17:58:04
| [2022-09-30 18:40:38] |
| John - SC Support - Posts: 48597 |
In either case you need to be on one of the Integrated packages (package 10, 11, or 12). Refer to the following: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
