Date/Time: Mon, 26 Oct 2026 14:29:36 +0000
Rithmic demo
View Count: 1839
| [2022-09-30 16:07:31] |
| AMINE BERRECHACH - Posts: 26 |
Hi i want to use rithmic demo on siearra chart to receive market data but i wonder if this is possible, and i can’t use denali data feed because i can‘t afford exchange fees
| [2022-09-30 17:56:13] |
| John - SC Support - Posts: 48318 |
We are not sure what you are referring to in terms of a "Rithmic Demo". If this is part of a Prop firm/Evaluation, then this should not be a problem. Refer to the following for how to connect your Sierra Chart to Rithmic: Rithmic Trading Platform Service: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-30 21:17:16] |
What i mean with rithmic‘s demo is the free trial to test rithmic Go to this if you want to know what i mean https://www.rithmic.com/demo.html#sign-up&customer=OptimusFutures Can you tell me if i connect to this Can i get level 2 data? |
| [2022-09-30 21:37:31] |
Theoretically you should be able to connect to it, as Rithmic Paper trading servers are available. But we really do not know enough to say if it will work or not. We have given you 7 days of Package 11 in order to test the connection for yourself. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-30 22:57:31] |
Thank you so much SC support for this help and generosity,I appreciate this so much .you guys are the best i will definitely test this
