Date/Time: Fri, 09 Oct 2026 04:17:38 +0000
TPO colors
View Count: 1339
| [2022-09-30 16:01:37] |
| User513469 - Posts: 2 |
On the Windo Trader Blue software, it is possible to change the color of the TPO letters (when splitting the profile) based on the volume. A colorization is applied a bit like a footprint. Is it possible to do something like that with Sierra Chart? https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=69927 |
| [2022-09-30 17:39:41] |
| John - SC Support - Posts: 48161 |
There is not a way to color the letters/blocks based on volume. Refer to following for the coloring options available: Time Price Opportunity (TPO) Profile Charts: TPO Letter/Block Colors For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
