Date/Time: Wed, 23 Sep 2026 21:01:03 +0000
Teton Futures Order Routing, amp
View Count: 838
| [2022-09-29 22:39:45] |
| User485486 - Posts: 43 |
Hey, Does AMP support Teton Futures Order Routing? Do I need to update AMP as well if I want to switch to Teton? Where can I find a guide for this? Thank you, Shimshon |
| [2022-09-30 16:35:11] |
| John - SC Support - Posts: 47994 |
AMP does not yet support the Teton Order Routing service. It is being worked on, but not ready yet, and we do not know exactly when it will be ready. It is something you should ask AMP about. If you want to switch brokers to use the Teton Order Routing, then refer to the Setup Instructions here: Sierra Chart Teton Futures Order Routing: Setup Instructions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
