Date/Time: Wed, 18 Nov 2026 09:39:24 +0000
Candle closing more than 50% of it's size
View Count: 1094
| [2022-09-27 14:05:10] |
| User282978 - Posts: 11 |
Hi which study I can use to see if old, current candle close is more than 50%/midpoint ? And can I set variable % value instead of 50? Date Time Of Last Edit: 2022-09-27 14:13:52
| [2022-09-27 14:33:04] |
| John - SC Support - Posts: 48568 |
We are not sure exactly what the equation is that you want to create, but the Color Bar Based on Alert Condition would be the easiest way to do it. Take a look at the information for how to write Alerts at the following link: Study/Chart Alerts And Scanning To give you an example, if you wanted to color the bar when the bar total height (High - Low) is more than twice the size of the Open to Close, then you would write the Alert Formula like the following: =(H - L) > ABS(2 * (O - C)) Refer to the information for the Color Bar Based on Alert Condition here: Color Bar Based on Alert Condition For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-27 16:48:11] |
Thanks, I need to create C>=L+(H-L)/2 for green bar, I think this will give me if the bar has closed equal or more than 50% of it's size. I think i need multiple conditions. Date Time Of Last Edit: 2022-09-27 17:05:00
| [2022-09-27 17:20:17] |
just one more thing, can i use and operator i.e c>o and c>(L+h)/2 ?
| [2022-09-27 17:32:56] |
| ForgivingComputers.com - Posts: 1253 |
Think of Alert formulas like Excel formulas that can begin with "=". So your Alert formula would be: =C>=L+(H-L)/2
or more simply: =C>=(L+H)/2
Date Time Of Last Edit: 2022-09-27 17:40:15
| [2022-09-27 17:33:04] |
You need to use the AND() function. So it would look like the following: AND(C > O, C > (L+H)/2) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
