Date/Time: Mon, 02 Nov 2026 07:41:20 +0000
Managing output saved screenimages name formatting
View Count: 662
| [2022-09-24 08:27:54] |
| Usuario - Posts: 24 |
Hi. The screen image file-saving function works well. I was wondering if there is an option to configure the name of the files, or at least modify their "saving" parameters. For example, most files have this structure with brackets: HGZ22-COMEX [CV][M] 4 Min #8 2022-09-24 10_09_05.805. Specifically I would be interested in saving the file without the brackets if possible. Some possibility? Thank you. |
| [2022-09-26 13:49:44] |
| John - SC Support - Posts: 48377 |
There is not a way to change the file naming when saving images.
