Date/Time: Mon, 02 Nov 2026 07:41:19 +0000
Trade fx with SC/LMAX+receive level 5 SC for ES-billing issue
View Count: 664
| [2022-09-23 17:47:01] |
| bootsy - Posts: 63 |
Hi there, Am looking to trade spotforex and cfds using my LMAX account and trade off SC charts. However I also trade ES futures with another broker and would still need the ES data feed to come in to populate charts and see volume studies with SC (volume profile/numbers bars etc). I understand that I will need Service Package 11 in order to do this which is 46 pcm. However I have paid in advance for a few more months (at least!) of Service Level 5 at 36 pcm. Do I have to wait for this to run out and then upgrade to Level 11? Many thanks for your help, Ted |
| [2022-09-23 21:12:22] |
| John - SC Support - Posts: 48377 |
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
