Date/Time: Mon, 02 Nov 2026 08:31:45 +0000
choice of account to trade in trader pro by Rithmic
View Count: 1448
| [2022-09-21 13:34:22] |
| philippe zettor - Posts: 4 |
translated to: hello during my trading session I have two accounts in rithmic BX0XXXXX-02 and BX0XXXX-01 when I select in rithmic trader pro my account BX0XXXXX-02 but unfortunately my Dom de sierra does not want to take it into account it remains blocked on the account BX0XXXX-01 I remain at your disposal for more details cordially philip (original french) choix du compte a trader dans trader pro de Rithmic bonjour pendant ma session de trading j ai deux compte dans rithmic BX046646-02 et BX04664-01 quand je selectionne dans trader pro de rithmic mon compte BX046646-02 mais malheureusement mon Dom de sierra ne veux pas le prendre en compte il reste bloquer sur le compte BX04664-01 je reste a votre disposition pour plus detail cordialement philippe Date Time Of Last Edit: 2022-09-21 13:34:49
| [2022-09-21 16:29:40] |
| John - SC Support - Posts: 48377 |
First, refer to the following for how to change Trading Accounts within Sierra Chart: Basic Trading and the Trade Window: Main/C >> Trade Account (Selecting Trade Account for Chart / Trade DOM) If your Trade Window does not have both Rithmic accounts listed, then make sure that these are both available when you connect to your Rithmic account. Sierra Chart can only pull in multiple trading accounts when they are available under the same login to your trading service. If these are under two different Rithmic accounts, then we recommend installing a second Sierra Chart and connecting one Sierra Chart to one Rithmic account and the other Sierra Chart to the other Rithmic account. Refer to the information at the following link for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
