Date/Time: Mon, 02 Nov 2026 08:32:15 +0000
Data for GC COMEX Gold stopped working
View Count: 1713
| [2022-09-20 13:36:36] |
| ErikT - Posts: 121 |
I have Denali/SC ORS with all the futures data feeds enabled (non-pro bundle). Lots of charts in my .CHT which have all worked fine for years. Suddenly the Gold chart (Symbol GCZ22_FUT_COMEX) stopped working. Historical chart shows thru yesterday's close but not today's data, and intraday chart won't display at all. I tried using Find Symbol to make sure I had the right symbol and then opening a Trading DOM just in case the problem was in my chart settings. As expected, no live market data in the DOM either. Feels like COMEX live data got inexplicably turned off in the CME Futures bundle data feed. Please advise what I should do to fix this. Thanks! |
| [2022-09-20 13:48:58] |
I should have mentioned: This is SC 2439 on Windows 10.
Date Time Of Last Edit: 2022-09-20 13:49:47
| [2022-09-20 14:04:38] |
| Sierra_Chart Engineering - Posts: 25347 |
Give us about five minutes. We apologize for this. It affects only the TT order routing service.
| [2022-09-20 14:14:54] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-09-20 14:39:24] |
I confirm this solved my problem. Thanks!
