Date/Time: Mon, 02 Nov 2026 08:31:48 +0000
[Programming Help] - Can't load custom dll
View Count: 875
[2022-09-19 06:11:16]
User857150 - Posts: 11
Hello.
I wrote my own study and compiled it to dll.
Then, I put it in the Data folder, however, when I try to add this study (ADdd custom study) from Sierra Chart I get the following error:
------------------------Error from SC Message Log----------------
Found DLL: libMyStudy.dll | 2022-09-19 01:02:31.145
Found DLL: UserContributedStudies_64.dll | 2022-09-19 01:02:31.145
libStudy.dll loading error. Windows error code 126: The specified module could not be found. | 2022-09-19 01:02:31.161
VersionNumber is 0 for libStudy.dll | 2022-09-19 01:02:31.161
InternalVersionNumberToFileNameMap is empty for libStudy | 2022-09-19 01:02:31.161 *
Closest match search for: C:\SierraChart\Data\libStudy.dll returned empty result. | 2022-09-19 01:02:31.161 *
Notice!
I build this study using Clion using gcc compiler. The study works perfectly on my Sierra Chart on my PC, but when I move the same file to my server (Windows Server 2016) I get this error.
Both programs are built with the same version of Sierra Chart 2439.
What is the problem here and how to fix it?
[2022-09-19 18:07:29]
JustinQuant - Posts: 5
same problem here,need to be solved,occured time to time and cannot find the reason!!!
