Date/Time: Mon, 02 Nov 2026 08:31:25 +0000
New Bar At Session Start
View Count: 2407
[2022-09-19 00:43:50]
User223734 - Posts: 120
Dear Sir,
For "HSI Futures" :
When I select "Chart" > "Chart Settings" > S"ession Times" > "New Bar At Session Start" > "No"
The chart still continue as new bar at session start, please advises the reason.
[2022-09-19 11:42:31]
Sierra_Chart Engineering - Posts: 25347
This may depend upon the time duration of the bar and the Session Times.
[2022-09-20 10:37:16]
I am using 4hours duration Bar.
[2022-09-20 15:52:21]
Then depending on your Session Times, you may just be ending up with the last bar ending just before the start of the new trading day. For example, if your session times are 24 hours (like 08:00 - 07:59:59) then you will always have a new bar at the beginning of the session since 24 hours is evenly divisible by 4.
