Date/Time: Mon, 02 Nov 2026 08:31:26 +0000
Unable to assign keyboard shortcut to selected command
View Count: 667
| [2022-09-16 13:37:10] |
| Nick_ON_CAD - Posts: 22 |
Keyboard Shortcuts > Chart > Scale: All "Constant Range: ...." options exist but do not appear under "Selected Command" when selected. Therefore, one cannot assign a keyboard shortcut even though those commands are listed in the keyboard shortcuts menu. Your software is amazing, and I appreciate your hard work. Thanks, Nick |
| [2022-09-16 15:44:19] |
| Sierra_Chart Engineering - Posts: 25347 |
We will check on this.
| [2022-09-16 20:27:01] |
This will be resolved in the next release.
| [2022-09-16 20:38:28] |
Thank you so much. Would there be anyway to add option to add these as control bar buttons too? I'm more than happy with the keyboard shortcuts but would be nice to have the option to assign a button. Thank you, Nick |
| [2022-09-19 21:25:43] |
Yes we can add control bar buttons. We will do that.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-20 09:03:32
