Date/Time: Mon, 02 Nov 2026 09:18:45 +0000
The platform continuously loads data until the message - you have exhausted the number of
View Count: 1265
| [2022-09-12 13:58:27] |
| User716459 - Posts: 204 |
The platform continuously loads data until the message - you have exhausted the number of daily logins - appears. I am asking for quick help, attached Sierra messages, thank you.
Private File |
| [2022-09-12 14:10:02] |
| Sierra_Chart Engineering - Posts: 25348 |
Sierra Chart has no control over this. This is a CQG error. One reason we do not like CQG. You will not have this problem with Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-12 14:10:25
| [2022-09-12 15:34:32] |
I activated real-time Denali and platform the platform is not working.
| [2022-09-12 15:52:48] |
ok :)
| [2022-09-12 17:37:31] |
It does not help to use the Denali Data Feed. You have to go to the Teton order routing service which is not a simple process. Who is your futures broker?
