Date/Time: Mon, 02 Nov 2026 09:18:56 +0000
Problem with Quote Board and Binance symbol settings
View Count: 1470
[2022-09-12 08:23:49]
User995923 - Posts: 64
Hello I have a Quote board with many symbols.
Lately I started trading crypto so I tried to include various binance symbols into the Quote Board but there is a problem.
For the sake of simplicity I will mention two of them BTCUSDT_PERP_BINANCE and ETHUSDT_PERP_BINANCE.
The tick size of these two symbols is extremely small making the TPO chart unreadable plus the loading time freezes sierra chart.
So I go to Global Symbol Settings (Use custom symbol Settings Valued is selected) and I find that all binance symbols are pooled together. ETH is 1700 and BTC is 22000 so if I want a tick size of 0.01 for ETH and a tick size of 0.1 for BTC this cannot be done.
Also if I choose the option in Chart Settings/Symbol Settings Auto-Set From Data Feed set to NO, when I choose another symbol from the Quote Board, the Auto-Set option turns back to YES.
I have read that I can create some custom symbols but some of my charts are historical and not intraday, so it does not work.
So how can this be solved? Can you create a few binance symbols apart from the pooled Binance symbol?
Thanks.
[2022-09-12 08:54:21]
Sierra_Chart Engineering - Posts: 25348
Yes you do need to create custom Symbol Settings in the Global Symbol Settings for the symbols you want to set specific settings for.
This does not matter at all:
[2022-09-12 09:02:10]
I have created a custom symbol.
If I go File-> Find Symbol, then choose it, then Open Intraday Chart it opens normally.
If I choose open Historical Chart it says Download Failed and there is no Chart.
Is there a way around this? I use some historical charts for my analysis.
[2022-09-12 09:06:21]
You need to Duplicate the settings for an existing Binance symbol to make sure you have the correct basic settings.
Date Time Of Last Edit: 2022-09-12 09:06:30
[2022-09-12 16:04:46]
Ok I found it, thank you very much!
