Date/Time: Mon, 02 Nov 2026 09:18:24 +0000
wronglz connected lines on exit
View Count: 765
[2022-09-11 09:13:34]
User30743 - Posts: 399
hello, there is a strange issue when i close a position, sierra draws a connecting extry-exit lines from past and also calculates pnl wrongly.
It is very annoying and i dont know how to solve it. It seems as if sierra holds some reference to a previous exit as entry or something like that
can u please let me know what to do to get rid of this? Maybe i just need to reset or delete somethiong and it will all good, but i dont know what and where.
I am sending u screenshot to get better idea. I trade only intraday and as u can see, the lines spanes mutiple intradaz sessions, because sierra hold previous exit as entry point.
see the screen https://prnt.sc/9Ko9HDvZxhXe
[2022-09-12 14:05:32]
We have to admit that what you are seeing is particularly odd, as typically there is a missing fill in your Trade Activity Log and the connecting lines then are off by a single fill. But what you are seeing is much more than this.
Still, the solution should be the same, which is to find a point at which you do not have any open positions and then set that as a starting date-time to move forward from. Refer to the information here:
Trade Activity Log: Understanding and Setting the Start Date-Time for a Trades List
Also refer to the following:
Trade Activity Log: Solving Inaccurate Trade Statistics for Charts Field Values
Date Time Of Last Edit: 2022-09-12 14:06:45
