Date/Time: Mon, 02 Nov 2026 12:11:58 +0000
CME
View Count: 648
| [2022-08-30 18:26:38] |
| stckmd - Posts: 4 |
Hi im trying to get my market data for CME ES and E mini on my Sierra Chart. I signed up for the 12 tier but it isnt coming through. Also Im with Amp Futures and I need to find out how to connect the two please
| [2022-08-30 19:14:41] |
| John - SC Support - Posts: 48377 |
Since you are with AMP, then most likely they have set you up with CQG for your order routing service. Follow the instructions at the following link to connect your Sierra Chart with your CQG account: CQG Trading Platform Service: Setup Instructions With regards to the data, you need to activate the exchange(s) you want at the following link: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges We see that you have enabled the Sierra Chart Exchange Data Feed. If you need data from this data feed, then be sure to finish filling out the agreements and activating the exchange(s) you need. Otherwise, be sure you deactivate the connection so you are not charged again for this on the first of next month. You can deactivate the connection at the following link: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures&UserID=255245#DataConnections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
