Date/Time: Wed, 18 Nov 2026 09:39:42 +0000
Customize colors for cumulative delta bars
View Count: 1203
| [2022-08-25 13:53:47] |
| Mark_47 - Posts: 27 |
There is a way to color the "CUMULATIVE DELTA BAR - VOLUME" chart using "COLOR BAR BASED ON ALERT CONDITION"? I am already doing this with the price chart based on various criteria .. but I cannot understand if it is also possible to do it with the delta chart. Thank you very much. Date Time Of Last Edit: 2022-09-02 16:21:16
| [2022-09-02 16:21:21] |
up!
| [2022-09-02 19:07:06] |
| John - SC Support - Posts: 48568 |
Yes, it works fine on a Cumulative Delta Chart. You just need to ensure that you have the "Based On" for the Color Bar Based on Alert Condition set to the Cumulative Delta and that the "Region" is set to the same as the Cumulative Delta. From there, you just need to enter your Alert condition correctly.
| [2022-09-03 13:20:18] |
thanks john as always :)
