Date/Time: Sat, 19 Sep 2026 15:03:13 +0000
DOM cannot remove some cols
View Count: 788
| [2022-07-29 15:15:23] |
| User177741 - Posts: 48 |
The Sell Order Col and Buy Order Col cannot be removed from the DOM! When you click on the Left arrow... nothing happens.
| [2022-07-29 18:28:05] |
| John - SC Support - Posts: 47939 |
That is correct. When you have the Trading Chart DOM On enabled, then you need to have one of the Bid/Ask Order, or Bid/Ask Size, or Bid/Ask Order/Size columns displayed - you can not remove it. To not have those columns you would need to disable the option for Trading Chart DOM On, which will remove all the columns. It is not possible to have other columns displayed without having at least the Bid/Ask columns also displayed. For more information, refer to the following: Global Trade Settings Windows: Bid Size/Buy Column - Left/Center/Right Aligned For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
