Date/Time: Fri, 13 Nov 2026 21:50:37 +0000
Recalculate Volume By Price
View Count: 1002
[2022-07-27 18:01:28]
QnReally - Posts: 188
Sierra Support,
I have an intraday chart with bar period set to 405 minutes (to cover regular trading hours of 9:30 ET - 16:15 ET for NQ). I wanted to obtain the data for peak/valley levels that extend until future intersection for each day by using the Volume By Price study. I am able to do that, however, the study has a performance hit (like 400 ms per run) because of the sheer number of bars (more than 1000 bars) loaded in the chart. I wanted to look into ways for Volume By Price study to consume less resources. Here are some thoughts I was hoping you would consider.
Add an option in the Volume By Price study to allow it run only on recalculation. If need be, I don't need the peak/valley lines for the last bar in the chart, so, no real-time data needs to be processed.
OPTIONALLY CONSIDER: Add an option to calculate each time a new bar is added to the chart.
OPTIONALLY CONSIDER: Add an option to calculate no more than once in X number of seconds unless a recalculation occurs.
Thanks.
[2022-07-27 18:22:29]
One other piece. I actually don't need to see the volume histograms. I just need the price levels. So, if you could add an option to the Volume Bars Draw Method input to not display/draw the histograms at all (hopefully, that will be good for responsive charts as well), that would be great. Thanks.
[2022-07-28 10:18:09]
What we could do is add an option to disable study calculations and just support a manual calculation through a command that can be triggered through a menu command, keyboard shortcut or control bar button.
Would that work?
[2022-07-28 16:55:50]
That would work if that setting is a Volume By Price study setting as opposed to being a chart setting that applies to all the studies on the chart, just to have no confusion. Thanks.
[2022-11-11 21:28:06]
Just checking back on this to see if it has been scheduled into your work stream. Thanks.
[2022-11-12 07:46:18]
No not yet. We will try to get to it soon.
