Date/Time: Mon, 02 Nov 2026 08:33:03 +0000
Thank you for adding the tool setting to Allow Copy to Other Charts... One request
View Count: 1436
| [2022-07-22 12:23:56] |
| HumblyTrading - Posts: 226 |
Hello SC Team, Some time ago, I requested this feature, and I'm glad that it is now part of the Tool Settings. Also, your work on reorganizing all the setting windows has made the application much more user-friendly. One further request: I am forced to turn this feature on and off constantly, because I use many drawing types, and when I am using text I do not want it to copy, while when using lines/rectangles/etc. I do want it to copy. Could the team please add a Shortcut key to toggle this setting on and off? Otherwise, could the team add a feature to control this by tool type, where each tool would have its own default behavior for copying new drawings. Thank you! In the meantime, I am trying to use a workaround with Keyboard Maestro. Mike T |
| [2022-07-26 04:40:35] |
Yes we can add a keyboard shortcut for this implemented in a similar way like Tools >> Move Drawing.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-26 04:40:50
| [2022-07-26 07:25:03] |
That would be ideal! Thanks!
| [2022-07-26 16:13:16] |
We will get this implemented.
| [2022-07-29 19:26:06] |
I am very excited about this! Thank you for putting it on the agenda! Mike |
| [2022-09-21 19:20:57] |
Thank you Sierra Chart for adding this feature. I use it constantly and have assigned it as a shortcut key accessible on my mouse, stream deck, etc. Mike |
