Date/Time: Sun, 05 May 2024 14:31:22 +0000
Binance Delayed Data
View Count: 1256
[2022-07-28 19:23:51] |
BojanSpa - Posts: 3 |
Most likely because of this: "The websocket server will send a ping frame every 3 minutes. If the websocket server does not receive a pong frame back from the connection within a 10 minute period, the connection will be disconnected. Unsolicited pong frames are allowed." |
[2022-07-30 16:44:21] |
User995923 - Posts: 64 |
So has the error been fixed?
[2022-07-30 19:58:44] |
Yes the problem is resolved and yes it is due to post #25. This was an error, by one of the programmers we were unaware of.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-30 19:59:05
