Date/Time: Wed, 25 Nov 2026 23:10:03 +0000
Rectangle similar to DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE
View Count: 1220
[2022-07-05 23:37:10]
QnReally - Posts: 188
Dear SC Support,
Would you be able to add support for a rectangle with Arrays[0] and Arrays[1] representing the width and the height of the rectangle similar to how you support custom size circles with DRAWSTYLE_TRANSPARENT_CIRCLE_VARIABLE_SIZE?
Also, it will be good to add all its related rectangle drawstyles like left, right, transparent, opaque, etc.
Thanks.
[2022-07-06 16:23:22]
We have set this as a Feature Request.
[2022-11-11 21:29:54]
Any chance of this coming soon? Thanks.
[2025-12-11 20:53:55]
Sierra_Chart Engineering - Posts: 25485
We will check on this. We apologize for the delay.
[2026-02-22 20:25:46]
This is now all supported in the next release:
/* These apply to the following two Draw Styles : Subgraph value controls vertical
positioning. Arrays[0]=Width in pixels, Arrays[1]=Height in pixels,
Arrays[2]=Alignment relative to chart bar (0=left, 1=right, 2=center)*/
, DRAWSTYLE_CUSTOM_RECTANGLE
, DRAWSTYLE_CUSTOM_RECTANGLE_TRANSPARENT
Date Time Of Last Edit: 2026-02-22 20:27:09
