Date/Time: Wed, 30 Sep 2026 19:57:25 +0000
Traded Window buttons disabled improvements
View Count: 687
| [2022-07-01 00:19:35] |
| User177741 - Posts: 48 |
Hi, Sierra Chart is the best trading software period! I couldn't trade without it. I would like to be part of making this software better! Notice on the Trade Window that when we have the buttons disabled.... they don't completely "gray out". See attached screen shot. It would be nice if they complete gray out and look disabled. Please consider it! Kim |
Attachment Deleted. |
| [2022-07-01 13:30:00] |
| John - SC Support - Posts: 48074 |
Thank you for the kind words and the suggestion. As you are probably aware, we are working on new windows, and the first of these have been the Settings windows that have changed. We will eventually be moving all our windows to this new format, as these are directly developed by us and do not rely on any third party software (or Microsoft). We are telling you this, because the Trade Window will eventually be changed over and therefore we are not going to be putting any changes into the existing window. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-07-01 15:34:24] |
Excellent to know! Keep up the great work!
| [2022-07-04 09:57:35] |
Also, those buttons are disabled at the operating system level and the current appearance is based upon how it is controlled by the Windows operating system. However , maybe we could change the button text and colors in a disabled state to give a different appearance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-04 09:57:42
