Date/Time: Sun, 01 Nov 2026 07:33:38 +0000
Quote Spreadsheet
View Count: 737
| [2022-06-24 19:20:13] |
| User841161 - Posts: 357 |
On Quote Spreadsheet- says daily change for CL122 have daily change of -.22, when daily change should be positive. Don't know where the daily change figure is coming from. Daily change should be 107.41-103.99=3.42.
| [2022-06-24 20:41:43] |
| John - SC Support - Posts: 48377 |
Refer to the information for the Daily Change in this section: Getting Quotes: Field Descriptions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
