Date/Time: Sun, 01 Nov 2026 08:22:17 +0000
Spreadsheet Formula Cell Pink Corner
View Count: 685
| [2022-06-24 13:07:53] |
| ycomp - Posts: 334 |
I'm getting a pink corner triangle on the cell of any cell that I put in a formula in. I'm not sure if I'm doing something wrong. What is happening? In case this is just some kind of visual cue that there is a formula there, how can I disable it? I need to put formulas in a large block of cells, it would be annoying to see pink corners on all of them. |
| [2022-06-24 14:05:03] |
| John - SC Support - Posts: 48377 |
You are correct, this is a function marker. The only way to get rid of it is to change the size to 1 and then change the color to the same as the background. This is done through the Graphics Settings >> Spreadsheet Function Marker Color. Refer to the following: Graphics Settings: Spreadsheet Function Marker Color For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
