Date/Time: Sun, 01 Nov 2026 08:22:42 +0000
Uprofit connection
View Count: 1157
| [2022-06-23 16:01:56] |
| User977732 - Posts: 16 |
if i already have a live account from amp futures, and i want to use Uprofit trader account to trade, do i have to suscribe denali datafeed and how to connect the Uprofit account with denali datafeed?
| [2022-06-23 19:55:25] |
Follow through the Rithmic set up instructions here: Rithmic Trading Platform Service: Setup Instructions You will need a separate installation of Sierra Chart for Rithmic: Using Multiple Data and Trading Services at the Same Time You do already have access to the Denali Data Feed and you just need to activate the exchanges you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
