Date/Time: Sat, 31 Oct 2026 23:54:54 +0000
Making VP wider and more visible
View Count: 843
| [2022-06-21 15:01:55] |
| Jaydtrade - Posts: 125 |
I am certain there is a way to make these Volume Profiles wider. I just cannot seem to get it to work. They are very thin and I cannot seem to spread them and make them more defined. I have messed with every setting in the study and cant seem to figure it out. Any help would be appreciated! See attachment. The profile is very thin and hard to see peaks and valleys.
Date Time Of Last Edit: 2022-06-21 15:02:08
| [2022-06-21 15:06:51] |
| John - SC Support - Posts: 48377 |
The following input and the one after it control how far the profile extends: Volume By Price Study: Maximum Volume Bar Width Type We recommend using the Period Length with a value of 70%. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-22 13:25:50] |
Thanks John perfect!
