Date/Time: Sun, 01 Nov 2026 08:26:02 +0000
Denali data for Tradingview
View Count: 1863
| [2022-06-20 15:21:51] |
| User300096 - Posts: 8 |
Hello - have recently migrated data from CQG to Denali per SC's recommendations. It has not been an easy transition; now, I used to be able to use my CQG data feed for both SC and Tradingview. Is there a way to connect Denali to Tradingview? If not, is this something currently in the works?
| [2022-06-20 15:35:07] |
| John - SC Support - Posts: 48377 |
The Denali Exchange Data Feed only works with Sierra Chart and we do not expect to ever make it available to other services. Therefore, if you are using both Sierra Chart and TradingView, then you would need to use the Denali data for Sierra Chart and CQG for TradingView. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
