Date/Time: Sun, 01 Nov 2026 08:25:13 +0000
Question about [Trade Activity Log]: DTC historical fill
View Count: 767
[2022-06-17 19:12:33]
Tony - Posts: 731
I tried to delete Non-Sim trades entries by doing (Rithmic):
1, exit Sierra Chart;
2, delete all files in 'TradeActivityLogs' folders
when I run Sierra Chart again, those deleted entries appear in Trade Activity Log again
with ending [- DTC historical fill] instead of [- DTC (Filled)]
Attached a screenshot, the last 2 fills are new trades, previous 6 entries don't show during
replay, and cannot be accessed by sc.GetTradeListEntry() either.
wonder why that happened?
thanks!
Date Time Of Last Edit: 2022-06-18 21:36:32
imageDTC.png / V - Attached On 2022-06-17 19:12:23 UTC - Size: 87 KB - 206 views
[2022-06-17 21:34:24]
Sierra_Chart Engineering - Posts: 25338
You need to look at the Symbol and Trade Account for those fills and make sure they are correct. Also check the fill price and quantity.
Date Time Of Last Edit: 2022-06-17 21:42:19
[2022-06-17 23:34:55]
Tony - Posts: 731
All 8 entries are the same symbol and same account, no issues with fill price and quantity either.
I would just like to know why after I deleted the first 6 entries, they still appear like ghosts, maybe there are more files need to be deleted that I don't know?
[2022-06-18 20:10:14]
We do not know what is meant by this:
[2022-06-18 21:45:09]
Tony - Posts: 731
My bad, I should have mentioned the document related to this subject:
Trade Activity Log: Clearing Trade Activity Data Through Files
Regarding my original post (post #1)
I followed the instruction, the document says: "These files must only be deleted when Sierra Chart is not running.", so the 1st step I did is to exit Sierra Chart;
and the 2nd step I did is to delete all the files in the "TradeActivityLogs subfolder in the Sierra Chart installation folder"
After run Sierra Chart again, I was expecting an empty Trade Activity Log, but all the entries I made are still there, the only difference is that in [OrderActionSource] column, those entries that were failed to be deleted, shows:
Rithmic Direct - DTC historical fill
instead of:
Rithmic Direct - DTC (Filled)
So, I don't really know what happened, is it because Sierra Chart gets historical fills from Rithmic server? or there are files that store fills information on my hard drive also need to be deleted, that I am not aware of?
Thanks for your help. I really feel sorry that you had to reply my message on a Saturday.
Date Time Of Last Edit: 2022-06-19 02:32:18
[2022-06-20 17:55:40]
Yes this is what happens.
