Date/Time: Sun, 01 Nov 2026 08:24:05 +0000
Text balance faulty
View Count: 726
[2022-06-17 16:48:04]
User554643 - Posts: 5
Hi, How are you? My name is Frank and I want to ask you, why is the balance not showing correctly on the chart? In the chart settings i applied the balance text and it shows me 0.00, can you help me?, even though i
have more than 0.00 on my account, this occoured when i rolled over the chart to September. The trading DOM is also bugged/faulty.
[2022-06-17 17:19:14]
Which balance are you specifically referring to, as the word "balance" is not used in any of the Chart Settings, so we are confused on the exact item you are referencing. And is this for your live trading account or in Simulation Mode?
[2022-06-20 12:49:05]
Hi, the uploaded chart shows what i was asking about(circled in blue in the attached files).
imageamp chart.JPG / V - Attached On 2022-06-20 12:48:08 UTC - Size: 154.82 KB - 280 views
[2022-06-20 13:05:33]
First thing to do is to check the Account Balance in Trade >> Trade Account Monitor.
Do you see the correct value there?
Regarding this:
Provide an image of the chart or Trade DOM, by following these instructions:
Date Time Of Last Edit: 2022-06-20 13:05:45
[2022-06-20 13:21:54]
Hi, The trade account monitor shows the correct balance and here is an image of the chart with the trade dom being faulty.(https://www.sierrachart.com/image.php?Image=1655731199795.png)
[2022-06-20 15:08:09]
We will solve the problem with the account balance study. This will be out in the next release coming out in one or two days.
We do not understand what the problem is with the Chart DOM.
Date Time Of Last Edit: 2022-06-20 16:08:46
[2022-06-20 18:55:39]
The DOM has these bars on the recent bid volume and recent ask volume which cover the numbers and it is not possible to see the current figures. This can be seen in this image (https://www.sierrachart.com/image.php?Image=1655731199795.png).
[2022-06-20 18:59:14]
Refer to the following information for how to change the status of the Volume Bars displayed in the DOM Columns:
Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns)
Note that the exact method has changed and we have not had a chance to update the documentation. You will have a pulldown menu option for the Volume Bars instead of just the checkbox.
