Date/Time: Sun, 01 Nov 2026 08:24:05 +0000
M6E not working as trade only symbol on 6E chart
View Count: 1429
[2022-06-16 18:11:09]
User187934 - Posts: 40
I have a 6EU22_FUT_CME chart and want to set the trade and current quote symbol as M6EU22_FUT_CME but when I do this there are issues with how the working orders show on the chart and the orders being placed. If I market in then my bracket order does not show on the 6E chart and it looks like the stop order is not being placed on M6E either. I think this may have something to do with the tick size and price display units being different on the Micro but am not sure if this is the case. Is there a way to solve this?
Private File
[2022-06-16 19:31:29]
Yes this is solvable. The actual native exchange price format is different between the two of the symbols and that is the reason for the problem. For instructions to solve this, refer to:
Sierra Chart Teton Futures Order Routing: Using Trade Symbol
[2022-06-17 07:40:05]
Thank you that is mostly working now however if I place a sell limit order above price on the 6E chart then it does not work but if I place a buy limit below price on the same chart then it does work. Also I was in a position and then place the sell limit above as a take profit but this immediately closed the position and at a very strange price. It looks like it was a decimal error as the position closed at 10614.xxxx instead of 1.0614. Any ideas on this and why the buy limit seems to work but not the sell limit?
[2022-06-17 08:12:40]
What did you set this setting to:
Chart Settings: Trade and Current Quote Symbol Price Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
It needs to be 1.
[2022-06-17 08:27:29]
These are the settings on the 6E chart
imageScreenshot 2022-06-17 102639.png / V - Attached On 2022-06-17 08:26:55 UTC - Size: 47.44 KB - 276 views
[2022-06-20 07:21:51]
Sierra_Chart Engineering - Posts: 25338
We will test this.
[2022-06-20 18:20:14]
Regarding post #5, those settings are correct. We are not seeing any order entry issues ourselves during testing:
https://www.sierrachart.com/image.php?Image=1655748951206.png
We are submitting orders for the micro contract.
We tested both buy and sell orders.
Order fills prices looked correct as well:
ActivityType  DateTime  TransDateTime  Symbol  OrderActionSource  InternalOrderID  ServiceOrderID  Quantity  OrderStatus  OrderType  ClientOrderID  Price2  BuySell  Price  FillPrice  FilledQuantity  TradeAccount  OpenClose  ParentInternalOrderID  PositionQuantity  FillExecutionServiceID  HighDuringPosition  LowDuringPosition  Note  AccountBalance  ExchangeOrderID  TimeInForce  Username
Fills  2022-06-20 14:18:37.084245  2022-06-20 14:18:37.166000  M6EU22_FUT_CME  Teton CME Order Routing (Filled). Info: CME (Fill)  32030  954  1  Filled  Market  32030.42719    Buy    1.0752  1  Test101  Open    1  521842588551202206211_M6EU2        0.00  521842588551  Day
Fills  2022-06-20 14:18:37.147007  2022-06-20 14:18:37.166000  M6EU22_FUT_CME  Teton CME Order Routing (Filled). Info: CME (Fill)  32029  953  1  Filled  Limit  32029.60605    Sell  1.0752  1.0752  1  Test101  Close      521842588497202206211_M6EU2  1.0752  1.0752    0.00  521842588497  Day
Disable the use of Custom Symbol Settings. This is explained here:
Date Time Of Last Edit: 2022-06-20 18:21:01
