Date/Time: Sun, 01 Nov 2026 08:24:13 +0000
Missing forex live data
View Count: 996
| [2022-06-16 13:59:07] |
| User447007 - Posts: 44 |
As I see FXCM does not provide data for the folowing forex items: DKK,HUF,SGD, THB, ILS, PLN, KRW, SAR,AED , CZK Is there any Sierra/ 3rd party data feed to get live intraday data + volumedata for that currencies? |
| [2022-06-16 14:32:32] |
You could use the MorningStar Forex data available through the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed This will cost about 50 USD per month between the cost of the data feed and the fee for MorningStar. We see that the MorningStar Forex exchange is not currently listed but we can list that. We do have it available to us. We have one other user who is using it. Regarding volume data we would not rely upon it for volume data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-06-16 15:11:13] |
Thank you, it would be fine. So do they have live volume data or not?
| [2022-06-17 14:42:07] |
| [2022-06-17 17:40:10] |
If they had no intraday and historical volume data or you simply not recommend to use it, what is your solution for forex data provider with volume info too? I really like your software and I do think your service is the best on the market, but unfortunately we couldn't tell it about your FXdata provider... We could call FXCM anything, but professional... It is like you would have a NYSE/NASDAQ market data provider which would cover the big cap stocks, but forgot the mid and small cap ones... What kind of data serive would it be?? So please let me know what is the solution to find a real professional forex data provider, which's standard comes at least to close to Sierra Chart's level! |
| [2022-06-17 21:32:58] |
| Sierra_Chart Engineering - Posts: 25338 |
Thank you, it would be fine. So do they have live volume data or not? No, we do not think this is provided with that data feed.
| [2022-06-18 11:06:16] |
Ok, what is your solution for forex data provider with volume info too? I really like your software and I do think your service is the best on the market, but unfortunately we couldn't tell it about your FXdata provider... We could call FXCM anything, but professional... It is like you would have a NYSE/NASDAQ market data provider which would cover the big cap stocks, but forgot the mid and small cap ones... What kind of data serive would it be?? So please let me know what is the solution to find a real professional forex data provider, which's standard comes at least to close to Sierra Chart's level! |
| [2022-06-20 17:56:34] |
We do not know the answer to this.
| [2022-06-20 22:30:18] |
Ok, than start again. I would need live data with volume for trading forex pairs which covers small and exotic currencies too. As I see you have symbol list and EOD data for them with symbol ^... As far as I know Barchart use this symbol for forex, and they have live forex feed with volume according their homepage. You use another Barchart data too, so wouldn't be possible to use their feed in Sierra Chart? What about Esignal or Kinetick or Oanda or any other forex data provider? There are many forex data provider out there, or forex broker... None of their service/ data are suitable to use in Sierra Chart? |
