Date/Time: Fri, 23 Oct 2026 21:06:36 +0000
Global Graphic Settings & Tool Settings Font Size Changes
View Count: 877
| [2022-06-13 16:38:14] |
| FigJam - Posts: 6 |
Hi Support, I have SC installed on a laptop with a 17" 4k resolution monitor, but also (daily) trade on a 49" ultrawide external monitor. When I switch between the two, ALL font sizes in Global Graphic Settings automatically change to size 3 or size 29 depending on if I am switching to or from the 4k resolution monitor. Is it possible for this to stop happening so I do not need to go in and manually change every global font size in SC on a daily basis?
| [2022-06-13 22:11:30] |
| Sierra_Chart Engineering - Posts: 25251 |
Sierra Chart does not control this at all. This is all controlled and managed by the operating system. Sierra Chart has no control over this at all. For more information, refer to: Graphics Settings: Font Sizes Unexpectedly Changing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
