Date/Time: Wed, 14 Oct 2026 17:57:53 +0000
Feature request: Order column
View Count: 864
[2022-06-09 14:12:12]
User344261 - Posts: 4
Would it be possible to create a column for the Trade DOM where your active orders and EPIQ are displayed, vs having the order information extended out to the left?
I have attached a picture as an example. No need to combine with the PnL column, I just want a separate orders column, so I can make my DOMs narrower to fit more ladders on a screen.
Thank you.
imageOrder columns.jpg / V - Attached On 2022-06-09 14:10:01 UTC - Size: 284.19 KB - 325 views
[2022-06-09 16:28:17]
John - SC Support - Posts: 48204
We have set this as a Feature Request.
Just to let you know, when you are using a Trading DOM, the order lines are aligned to the right, up against the DOM ladder. `You can also make this the case with a Chart by adjusting the 2 settings starting here:
Chart Settings: Align Order Cancel (X) Button to Right (Chart >> Chart Settings >> Trading menu)
and the following one:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeDrawingsLeftAlignPercent
Date Time Of Last Edit: 2022-06-09 16:28:43
