Date/Time: Sun, 11 Oct 2026 16:50:01 +0000
Turning off "Automatic rollover for contract" for ES - STILL Switched , plse help
View Count: 656
| [2022-06-09 09:53:12] |
| HeyUgly - Posts: 287 |
attached pic every linked chart is set to NOT rollover auto contract. but it has Now i cant bring up the current contract on ES and it will Only let me load up next months. please help! i still have 3 weeks left on current contract |
| [2022-06-09 14:05:39] |
You definitely must have some unknown configuration causing this. It probably is related to chart linking. Set the Chart Link Number to None for the chart: Chart Settings: Linking And then see if you can change the symbol of the chart as you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
