Date/Time: Wed, 14 Oct 2026 17:56:57 +0000
how to un LOCK a trade in Silimuation ?
View Count: 704
[2022-06-09 07:43:26]
AC85898D - Posts: 20
I have set simulation and the un-lock is automatic there and I can not use simulation trade
Question: How can I UN-LOCK it ? i.e. disable LOCK mode in Simulation ?
Date Time Of Last Edit: 2022-06-09 13:30:13
[2022-06-09 15:13:53]
John - SC Support - Posts: 48204
We are not sure which lock you are referring to (there are a few options possible).
1. Make sure Trade >> Trading Locked is not enabled (no checkmark next to it). If it does have a checkmark, just select it to remove the checkmark and allow trading again. Refer to the following:
Trade Menu: Trading Locked (Trade menu)
2. If Global Profit/Loss limits have been met and trading is locked due to this, then you need to undo the locking item in the Global Profit/Loss and unlock trading as specified in #1 above. Refer to the following:
Global Profit/Loss Management: Lock Trading (Global Settings >> Global Profit/Loss Management)
