Date/Time: Sun, 11 Oct 2026 16:49:58 +0000
Re-attaching time & sales window issue (2396)
View Count: 631
[2022-06-09 06:04:30]
tenikis - Posts: 10
I have detached several time & sales windows using the settings > attach/detach/window option on them. None of them will now re-attach using the same menu command, is there something else to try or is this an issue with 2396?
Thanks, Ten
Date Time Of Last Edit: 2022-06-09 06:07:09
[2022-06-09 07:51:57]
We have no problem with this at all. Attaching and detaching a Time and Sales window works properly. And there have been no changes with this functionality .
If the window is not visible go to Chart >> Reset Child Windows.
