Date/Time: Sun, 11 Oct 2026 16:49:57 +0000
ayuda tecnica, de conexion de datos
View Count: 822
| [2022-06-08 16:58:31] |
| luciana - Posts: 24 |
Hola, contrate el corredor AMP FUTURE, me abri una cuenta con fondos en CQG, tengo mi usuario y contraseƱa. En sierra charts tengo contratado el paquete 10, active la fuente de datos denail exchanges, y llene los formularios y acuerdos. Pero cuando ingreso a Sierra charts, en mi chartbook que lo tengo configurado para TPO, no veo nada. Esta con el simbolo F. US. MES22 y esta conectado con data CQG. Lo que deseo es usar las graficas que tengo listas de TPO y market profil , con MICRO S&P 500 pero con los datos de denail exchange, enlazado para hacer trading con mi cuenta de CQG con AMP FUTURE. Me pueden asesorar? |
| [2022-06-08 17:31:47] |
| John - SC Support - Posts: 48169 |
From Google Translate: Hello, I hired the AMP FUTURE broker, I opened an account with funds in CQG, I have my username and password.
In sierra charts I have contracted package 10, activate the nail exchanges data source, and fill out the forms and agreements. But when I go into Sierra charts, in my chartbook that I have it set to TPO, I don't see anything. Is with the symbol F.US. MES22 and is connected with data CQG. What I want is to use the charts that I have lists of TPO and market profile, with MICRO S&P 500 but with the denail exchange data, linked to trade my CQG account with AMP FUTURE. Can you advise me? The one issue we see is that you are wanting TPO profiles, but you are on Package 10. You need to be on Package 11 in order to use the TPO Profiles. To change your Package, follow these instructions: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to. When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
